Chromium plating thickness per P-106 of MIL-STD-808
I have a requirement for chrome plating per finish P-106 of MIL-STD-808 (MIL-HDBK-808). This spec calls for a minimum final plate of .025 mm (~.001") chromium per QQ-C-320 Type I, Class 1. However, QQ-C-320 (FED QQ-C-320 )Class 1 says the minimum thickness should be .00001". So, I am wondering if this is a typo in MIL-STD-808 or if it should really be a thickness 100 times the minimum specified in QQ-C-320.
Robert Byrne
Aerospace contractor - Stamps, Arkansas, USA
September 2, 2010
Robert,
There is one very important phrase you missed out on the Class 1 thickness as specified in QQ-C-320 and that is "Unless otherwise specified". MIL-STD-808 is indeed calling up a thickness several factors higher than QQ-C-320. The minimum thickness called up in QQ-C-320 is what would normally be considered a "flash" coating, very thin, usually decorative rather than functional. A thickness of 0.001" is not uncommon for chromium plating, in fact it can be plated considerably thicker than that and often is when trying to refurbish parts.
Brian Terry
September 7, 2010
