Best Corrosion Protection for an Automotive Door Hinge Pin?
I have a small home based company that produces and sells aftermarket products for "jeep" type vehicles. We are introducing a replacement door hinge pin. It is machined from carbon steel, has a head, a "spline" area for gripping the hinge body, a cylindrical body, and a 6 mm thread. I am concerned about corrosion. It is expected the customer will paint the head, the body is hidden in the hinge, but the threads at the bottom are exposed. I have read about both nickel and zinc plating and their characteristics and have some experience with both. Suggestions?
Bruce Plumb
Jeeper Keepers
Bruce Plumb
Product designer - Broken Arrow, Oklahoma, USA
September 2, 2010
Zinc Plate with yellow chromate and assemble with waterproof grease.
Or make them of stainless steel.
Zinc-Nickel Alloy Plating
Mike Dil
- Kunshan, China
September 28, 2010
