Electrochemical Impedance Spectroscopy
Hello,
I am a Ph.D. student in the department of chemistry. My work is based on Corrosion study, so I want to know more about "electrochemical impedance" study and to work on that. , but I am not getting enough material on this topic. i.e., impedance spectroscopy related to corrosion process. Please suggest me some research paper, journals and Books having information on Electrochemical impedance spectroscopy (connected to corrosion evaluation, if there is any source available please send it. I need all the latest information available on this topic.
Thanking you,
- Shimoga, Karnataka, India
September 2, 2010
A. Kumar,
I just typed "electrochemical impedance spectroscopy" in Google. I found about 355,000 results.
T.S.N. Sankara Narayanan
- Chennai, Tamilnadu, India
(ed.note: The good doctor offers a fascinating blog, "Advancement in Science" )
A. Kumar, part of your PhD training is to be able to find sources of information. Will you give someone else your PhD when you get it, if they tell you how to do things? I think not! I would suggest you start a literature search by using Chemical Abstracts or some other similar reference source. I, too, have just done a Google search and come up with 70,000+ references. Decide what you want to know about electrochemical impedance and corrosion and start your literature search; you will then build up your knowledge and expertise in the areas you want to specialise in. ![]() Trevor Crichton R&D practical scientist Chesham, Bucks, UK A. Dear T.S.N. Sankara Narayanan, ![]() Harry van der Zanden consultant - Tilburg, Netherlands |
A. For Harry van der Zanden
I agree with your view. Sometimes it is difficult to get the right information. So, I am suggesting a starting point to Mr. Kumar.
For Kumar,
The application notes of Gamry instruments and Autolab would be a useful starting point to understand the basics of EIS.
The following links will be useful:
www.gamry.com/App_Notes/EIS_Primer/EIS_Primer_2007.pdf
www.gamry.com/App_Notes/EIS_Primer/EIS_Primer.htm
www.ecochemie.nl/download/content/Appl012.pdf
www.metrohm-autolab.com/download/content/Appl013.pdf
www.chem.uw.edu.pl/studokt/wyklady/lasia/p1.pdf
www.consultrsr.com/files/Princeton_ACS_Impedance.pdf
For specific topics on EIS, one has to refer to the research papers in that area.
Q. Dear Sankara Narayanan,
The links that you provided are not working anymore.
- Korea
March 18, 2011
Ed. note-- That's pretty typical for the internet, Gobinda: 4 out of 6 links broken within 6 months .... all 6 broken when we re-checked not long afterwards :-)
Please go to the home pages that Sankara Narayanan suggested and see if the documents in question are available but relocated or try pasting the addresses he gave you into the Wayback Engine.
A. Here are some good references regarding EIS.
"Impedance Spectroscopy: Emphasizing Solid Materials and Systems," J.R. Macdonald, ed., 1987.
"Electrochemical Impedance: Analysis and Interpretation," J.R. Scully, et al, eds., 1993.
"Impedance Spectroscopy: Theory, Experiment and Applications," E. Barsoukov & J.R. Macdonald, eds., 2005.
"Electrochemical Noise Measurement for Corrosion Applications," J.R. Kearns, et al, eds., ASTM 1277, 1996.
- Naperville, Illinois
September 17, 2010
