Thermal Cycling in chrome plated ABS
I have problems with chrome cracking after thermal cycling.
The defect seems like "grooves".
Some specialists say that increase the copper thickness is the solution.
Is it true?
How can I solve this problem?
Engineer - Joinville, SC, Brazil
August 31, 2010
Hi, Estacio.
I don't know how thick your copper plating is, or how thick it should be, but I do know that the reason for copper plating of chrome plated ABS automotive components is thermal cycling resistance, so I'd say you're on the right track.
September 1, 2010
