Cyanide copper plating onto electroless nickel
I need to get a coating of cyanide copper onto electroless nickel (the substrate is cast aluminum) we are getting blistering from the base material every time we try.
RYAN DAVIESEMPLOYEE - England
September 1, 2010
Hi, Ryan. If you are going to do cyanide copper plating anyway, is there a reason that you precede it with electroless nickel? Apparently the cyanide copper plating is a good test for adhesion of electroless nickel onto aluminum :-)
Are you double zincating? Are you using an alkaline electroless nickel strike?
September 1, 2010
