Painting or powder coating the inside of hydraulic tanks?
Hydraulic Oil HLP 68 SERVO System.
Oil tank fabricated.
Does oil tank need to be painted/coated from inside?
employee - Ahmedabad
April 17, 2024
A. Hi Kunal
I don't think it's necessary or appropriate to paint or coat the interior of a hydraulic oil tank. The oil itself is non-corrosive; corrosion prevention involves keeping water and other corrosives out, while using proper quality hydraulic oils which include corrosion inhibitors which form films on the metal and protect it from corrosion.
Q. Dear sirs,
What is the best process for treating the inside surface of a hydraulic oil tank? Presently we are powder coating the interior surface. Is this OK? Will the powder coated surface react with hydraulic oil with a period of time?(say 20 years). will the powder coated paint peel off with oil?
Please help.
Product designer - Bangalore, India
August 30, 2010
? Some powders might come off with some oils. You haven't told us what powder you use? Nor what oil is in use?
But why coat it at all? What is your reason for putting a coating on the inside of an oil tank?
Geoff Crowley
Crithwood Ltd.
Westfield, Scotland, UK
A. The hydraulic oils I have come across contain some fairly aggressive solvents... I would suggest that you apply an epoxy based powder or even epoxy/phenolic powder (there are a few around). Anyone with any alternative ideas?
Terry HicklingBirmingham, United Kingdom
(many of these are rare; the links will only sometimes work)
Do oil tank plates require blasting before painting?
Q. Respected Sir,
I just have a small question. I want to know whether fresh plates of a new oil tank require blasting process before painting?
Also, will blasting increase the roughness of fresh plates? If the answer is yes, is this preferred before painting?
Hope you will help me.
NAFAL TRADING & CONTRACTERS-GHALA-MUSCAT - THRISSUR,KERALA, India
September 9, 2015
A. Hi John. Although I don't know what kind of tank or oil you are referring to, or what material the "fresh" plates are made of (hot rolled, cold rolled, galvanized) ... I think the question is really whether pretreatment is required; and the answer is yes, proper pretreatment (phosphatization) is required before painting. So if the plates can be properly phosphatized without blasting, that sounds fine. Good luck.
A. Hi John. I agree with Ted's comments. Depending on the media used, the roughness will probably increase. Blasting is sometimes preferred for this particular application but there are other methods that can be used to prep the material for further processing.
Blake Kneedler
