Electroplating on Tungsten Carbide (WC-Co)
I would like to know that whether it is possible to coat chromium (Cr) on (WC-Co) with electroplating technique? this is the first phase of my research University area.
Best regards,
Ayoob Ahrari
student - Johor, Malaysia
August 28, 2010
September 15, 2010
I came across this in PF online and it may helpful to you:
using a Wood's nickel strike as follows:
Component Concentration
Nickel chloride 30 - 34 oz/gal
Hydrochloric acid 14 - 18 oz/gal
Plate at ambient temperature and 30-150 asf. Immersion time is in the range of 1-4 minutes. The process cycle should be as follows:
1. Alkaline clean
2. Electroclean
3. Acid dip (50% hydrochloric acid)
4. Wood's nickel strike
5. Electroless nickel
S.GUNA
- SELANGOR, MALAYSIA
