Fix holes in steel barn roof from the inside?
Q. I have a very tall barn with a steel roof. It has a number of small holes and rather than go up on top (which is a very scary thought) I would much rather try to fix the holes from the inside. Can I plug the holes from the inside?
Dave Snihurhorse enthusiast - London, Ontario, Canada
August 21, 2010
A. You can try. Your degree of success will depend on the size and type of holes and your technique. If the holes are the result of corrosion, your repair will be only temporary, as the corrosion will continue. I'd suggest you try urethane caulk. ![]() Jeffrey Holmes, CEF Spartanburg, South Carolina < A. The easiest thing to do would be to squirt a small amount of real silicon caulk up thru the hole. A poor fix, but it is cheap-unless you fall. James Watts- Navarre, Florida A. Yes. Aerospace - South Wales, United Kingdom A. Somewhat old formula is mixture of iron powder (or zinc) and 'water glass' ⇦ this on eBay or Amazon [affil links] (thick paste), today you can use 2 parts epoxy cement mixed with iron powder (or zinc powder). Hope it helps and good luck! Goran Budija- Cerovski vrh Croatia |
