Nickel plated brass bolts compared to stainless steel
Our supplier is using nickel plated brass bolts instead of stainless steel. Which is better for outdoor use near the salt air/water?
Sally
Sally Fuentes
buyer - Lawrence, Massachusetts
August 16, 2010
August 17, 2010
Hi, Sally.
If the sole issue is corrosion resistance, I'd bet on the stainless steel bolts.
