Thread 555/08
Paint isn't adhering to Aluminium
I am painting some aluminium components attach to engine. I am using etch primer but till uneven paint peel-off is observed. I am doing Iron phosphating and Oven dry at 110 °C >etch primer> TSA top coat.
Paint peeloff is not observed at all parts.
Can anyone suggest solution?
Paint tech Engg - Mumbai, India
publicly reply to Nikhil Kute
August 13, 2010
Hi Nikhil,
In order for iron phosphate to be successful on aluminum, the phosphating bath needs to contain fluoride. Without knowing anything else about your process, I would ask your supplier about the composition of the iron phosphate and make sure that you have a product that contains fluoride.
- Naperville, Illinois
publicly reply to George Gorecki
August 16, 2010
If you mean a two pack etch primer (base and catalyst) then it has been used as a stand alone pretreatment since 1940's. Try your coating system without the iron phos... it is not needed. Note after mixing base and catalyst wait 5-10 mins before using and only mix sufficient for that day...never try to use it on the following day.
Terry HicklingBirmingham, United Kingdom
publicly reply to Terry Hickling
