  Thread 554/93
Stainless steel plating onto brass
We build tanks that are exposed to potassium acetate and potassium citrate liquid. These tanks have several fittings made of brass which over time is showing signs of corrosion. Is it possible to plate brass fittings with stainless steel? I need a surface that is compatible to these chemicals and stainless steel seems to be the only one or at least the obvious one.
Gerardo Aristi
Operations Manager - Chester, Connecticut, USA
publicly reply to Gerardo Aristi
August 10, 2010
Hi, Gerardo. No, it is not possible to electroplate stainless steel onto other materials, but you may find electroless nickel plating to be compatible with these chemicals.
publicly reply to Ted Mooney
What's wrong with solid SS fittings? G. Marrufo-Mexico
Guillermo Marrufo
Monterrey, NL, Mexico
August 14, 2010
publicly reply to Guillermo Marrufo
