Silver plated copper failing salt spray test
July 23, 2010
hi sir
copper contact 2 mm thick silver plated is getting failed in the salt
some problem. can you please suggest me some check point and parameters.
product designer - Delhi, India
July 27, 2010
Dear Shashi Kant Joshi,
silver plating is mainly for connectors/conductor, not for corrosion resistance.
Silver plating parts are not recommended for salt spray testing.
can I know the reason, why you are testing the salt spray for silver plating parts?
- Salem, Tamil Nadu, India
