  Thread 553/86
Waste Water Treatment
July 18, 2010
From the given analysis of the waste water, which substances are to be removed and how to remove? You are requested to please give a detailed procedure for this purpose.
1000 ppm C18H29NaO3S
few Organic Silicon
500 ppm (NaPO3)6(Mr��611.77)
500 ppm ZnSO4
NH2S03H
350 ppm ZnSO4
Polyhydric alcohol
Polyhydric
150 ppm (NaPO3)6(Mr��611.77)
Umair Altaf
student - Lahore, Pakistan
publicly reply to Umair Altaf
Hi, Umair. Is this one beaker full of solution you must treat, or hundreds of gallons per minute?
If you are indeed a student, you need to at least attempt some portion of your assignment yourself before you simply post your homework for someone else to do :-)
If this is an actual application, you should contact a wastewater treatment company and have them confirm and clarify your analysis and propose a treatment strategy which might include chemical precipitation, ion exchange, and reverse osmosis. Good luck.
July , 2010
publicly reply to Ted Mooney
