Kynar Paint as an isolator?
We are installing a 16 GA stainless brakeshape (angle) to a Kynar painted architectural aluminum panel in an exterior coastal environment. The stainless will be attached to the aluminum with stainless screws. Question is; Is the 70% PVDF 3-coat Kynar paint an adequate isolator or should an additional separator be used?
Jeff Garmeson
Architectural metal contractor - Rancho Cordova, California
June 30, 2010
July 11, 2010
Can you please be more specific about how you intend to isolate the screws. This would seem the larger dilemma?
Bill
William Doherty
Trainer - Salamander Bay, Australia
