Soft Electroless Nickel
Dear all,
I'm currently into soft electroless nickel plating
I would like to know
a) How can we differentiate between normal electroless nickel and soft electroless nickel?
b) any instrument to make a comparison?
regards
Ivan Tan
- Malaysia
June 24, 2010
June 25, 2010
Ivan,
Hardness from electroless nickel deposits can be tested using a vickers hardness testing machine. All EN plating solutions comes with a TDS with their specified hardness. Example, the common lead /cadmium free Mid P Electroless Nickel plating solution has a hardness ( as plated ) of about 500 HV ( 100 gms ). The 100 gms is the load of the indenter.If heat treated to 400 deg C ( 1 hr ) hardness can increase to 950 HV ( 100 gms ).Therefore, base on these info, what is the hardness requirement for your 'soft electroless nickel '?
SK Cheah
- Penang, Malaysia
