E-coat and Hydrogen Embrittlement
We supply a customer with a latch that has a forged steel component, which is e-coated. A recent lot showed signs of being brittle. Can e-coat andphoretic paint processes create hydrogen embrittlement?
Craig Bakerbuyer - Windsor, Connecticut, USA
June 24, 2010
July 29, 2010
Hydrogen embrittlement is normally never seen in CED coating. De embrittlement is carried out by heating the electroplated part as hydrogen embrittlement is very common in electroplating. An E-coated part is always baked and even if hydrogen embrittlement is suspected, this baking process should be curing it. I hope the part without the coating was also tested for comparison?
Gurvin SinghMohali, Punjab, India
Dear Craig Baker - Salem, Tamil Nadu, India August 6, 2010 Further to what Mr Gurvin has written, Id like to add that the current used in CED is too minimal to cause generation of Hydrogen and that the epoxy covers the component almost simultaneously ensuring no generation of Hydrogen. ![]() Khozem Vahaanwala Saify Ind ![]() Bengaluru, Karnataka, India ![]() |
