Masking Thread Holes on Aluminum Extrusion to be Black Anodized
Q. Please help and answer.
I have an Aluminum plate with a durable #2-56 thread hole array on it, and it is going to be Black Anodized.
What technique or procedure should be performed either do masking with machine screws inserted or anything else in order to keep those thread holes clean
Thank You in Advance
Lang Pai
product engineer - San Jose, California
June 18, 2010
A. Tapered plugs are your best option for masking multiple small diameter threaded holes for anodizing. Plugs are available in a wide range of sizes to fit many diameters. Rubber, neoprene and Teflon materials are available.
dayton dailey Dayton Dailey
supplier
- Lake Zurich, Illinois USA
June 22, 2010
A. These are tiny holes and while tapered plugs work ok for larger holes, silicon pull plugs are the best as far as sealing, ease of use and time savings. Any of the plug vendors at this site will be happy to send you a small sample of 1 or 2 sizes that would work best. Try before you buy.
These plugs are reusable for a few times if you are not rough on them.
A. Hello,
Is keeping the threads free a requirement, or simply a result of fears that the anodize will hurt the threads?
If you go with a type 2 anodize rather than a type 3 (hard) the threads will survive just fine. We've anodized more threads than ANYONE could count, and never had a problem from any quality angle. With thicker hard anodized coatings (type 3) you can make the edge of the threads so brittle that you end up compromising their ability to function, but that just isn't a concern with a type 2.
Good Luck.
Jim Gorsich
Compton, California, USA
November 2, 2010
