Rhodium plater is not ot achieving proper cleaning
Dear Sir,
I am a rhodium plater from since last 8 years and successfully running my plating business for jewelry. From last few months facing problem in rhodium plating which I am not able to get where the problem exactly is ?
After plating some diamond jewelry the diamond becomes a bit blackish in shade. Afterwards dipping it in sulfuric acid for 5-7 times it becomes OK but not very good. It also happens in some American diamond jewelry. But exactly where the problem is I am not getting. I am using best cleaning solution for it.
Please suggest me if there is a solution for it.
Mayank Soni
plating shop - Ahmedabad, Gujarat, India
June 4, 2010
You first check your rhodium plating on un-studded pieces. if same problem create than check your plating solution. or you clean your pieces in Teepol B-300 solution make the ultra. steam it and plate the Rh.
Bhupesh Mulik
- Mumbai, India
June 30, 2010
