Cadmium Plating on Aluminum Bronze Bushings
Can you Cadmium Plate Aluminum Bronze. Is it recommended.
Susan ChristensonQA Technician - Duluth, Minnesota
June 3, 2010
Susan,
You can cadmium plate aluminium bronze, it isn't normally done as the aluminium bronze is relatively corrosion resistant in its own right (dependent on grade).
June 9, 2010
