Electroforming (electroplating) onto Wax?
SUGGESTED ELECTROFORMING BOOKS
for Artisans, Jewelry, Crafts
electroforming_amiron
"A Beginner Guide on How to get Started with Electroforming" by John Amiron (2023)
avail from eBay, AbeBooks or Amazon
elecroforming_copper
"Copper Electroforming: An in-depth look into home copper electroforming" by David Hanson (2021)
avail from Amazon
electroforming_beginners2021
"Electroforming for Beginners" by Jason Welsh(2021)
avail from Amazon
electroforming_jewelry
"Electroforming" (Jewellery Handbooks) by Leslie Curtis (2013)
electroforming_for_artists
"Electroplating and Electroforming: A Guide for the Craftsman" by Scott Newman (1979)
Q. Hi all,
This is Rajesh from India. I am Hobbyist of wax art. Recently I read some article on hollow article prepared by using electroforming.
My idea is to create a wax art, paint it with electro-conductive material & electroform it using silver. I have searched a lot for electro-conductive paint for wax, but unable to locate any.
Please suggest me with the best option to do this (cheaper is preferred).
Thanks in advance.
Rajesh W
Hobbyist - Pune, Maharashtra, India
May 27, 2010
A. Pranam Rajesh
Try graphite powder this on eBay or Amazon [affil links] or bronze powder this on Amazon [affil links] . You may prepare your own conductive paint -- simply mix bronze powder with very diluted nitro lacquer this on eBay or Amazon [affil links] .
There are some very good infos on D-I-Y electroforming, some good and download free books on electroforming can be downloaded from internet archive website (even booklet by M.H.Jacoby -inventor of process/in german -- but try google translator, it is free. Hope it helps and good luck!
for Plating Shops & Engineers
Electroforming by Peter Spiro (1971)
avail from eBay or Amazon
Bureau of Standards: Electroforming of Waveguide Components
avail from AbeBooks or Amazon
Electroforming of copper for high vacuum applications
avail from AbeBooks
Fabrication of liquid-rocket thrust chambers by electroforming
avail from AbeBooks
A survey of electroforming for fabricating structures by W.H. Safranek
avail from AbeBooks
Electroforming in Restorative Dentistry
Principles of electroplating and electroforming by William Blum (1949)
A. Hi Rajesh,
A lot of people are doing electroforming on wax. Silver conductive ink this on eBay or Amazon [affil links] is the best option and is available. Try looking for it.
t k mohan
T.K. Mohan
A. Silver Electroforming can be done on wax in a Silver Potassium Cyanide Electroplating bath with higher metal concentration.
If the wax piece is finished properly than the result will be good ... Use a fine copper powder this on eBay or Amazon [affil links] mixed with NC thinner this on eBay or Amazon [affil links] and NC lacquer this on eBay or Amazon [affil links] and spray it on the wax, this will make the wax conductive ... rest of the electroplating process. If you want to make it hollow than you will have to deposit higher thickness, drain out the wax, and after that do the surface finishing. We are doing silver electroforming very effectively using the above process ....
Anand Khakhar
- Bhavnagar, Gujarat, India
A. Brass powder or gold powder or graphite powder; 3 powder : 2 lacquer : 16 thiner
Silver electroforming: 1-silver p cyanide, 2-potassium cyanide, 3-potassium carbonate, 4-potassium hydroxide, 5-antimony potassium tartrate, 6-selenious acid.
Majed Janineh
- Beith Lehem, Palestine
Is it necessary to remove wax from hollow electroformed jewelry?
Q. Please tell me if I have to empty my electroformed gold pendant of wax for sale and how can I do it?
Best regards,
nina mohebi
- shiraz iran
February 3, 2017
A. It is not necessary to remove the wax, but doing so will make the electroformed product much lighter! You will, of course, use a low melting point wax and have designed the electroform to have an escape hole for it, so all you do is carefully heat the electroform to a suitable temperature and the wax will flow out. Alternatively, you can use a suitable solvent, but that will depend on the type of wax used.
