pH is rising in Electrophoretic solution
Dear Sir.
I have problem with electrophoretic solution.
The pH is up.
What I can do for bringing down the pH.
Kind regards
- Damascus, Syria
May 19, 2010
First check conductivity of the bath.seems high.Ultra filtration will help.
Still if pH is high try adding dilute acetic acid
⇦ this on
Amazon [affil links] .
regards
T.K. Mohan
July 5, 2010
July 29, 2010
In a good electrophoretic bath with healthy production volumes, the pH will always rise. You have to add pH controller provided by the paint supplier to bring the pH down. Please do not add any chemical to the electrophoretic bath which is not supplied by the paint supplier.
Gurvin SinghMohali, Punjab, India
August 4, 2010
You can adjust the anolyte conductivity upwards
Sara Michaeli
Tel-Aviv-Yafo, Israel
