Using galvanized metal to make jewelry
Q. Hi
I am into stamping metal and making jewelry with it.. If I'm using galvanized metal, could that be harmful to the body?
Shannon Shackleton
hobbyist - La Jolla, California, USA
May 10, 2010
A. In suspecting that galvanized "metal" (only steel can be galvanized), could be "harmful", I guess you are thinking about the zinc that forms the galvanizing alloy coating on the steel's surface?
Here's a reference site about health of zinc.
http://www.zinc-health.org/
geoff_crowley
Geoff Crowley
Crithwood Ltd.
Westfield, Scotland, UK
crithwood logo
May 12, 2010
A. If galvanized = tin plated everything is OK. If you use zinc plated material everything is Ok too (in Europe cast zinc is one of materials for cheap jewelry, tin is expensive). I think that you must clearcoat your jewelry, probably Everbrite coating can be good option. Hope it helps and good luck!
