Factors Affecting Stripping Rate of Dry Film
Hi,
I would like to ask what are the factors attributing to the incomplete stripping of thick dry film (on copper substrate); we are using about 1.5 %KOH for stripping.
Does the conc. of OH affecting the power or any other factors such as the cleanliness of substrate before laminations?
Thanks. in advance
Eric Lam
Eric Lam- China
Dear Eric,
There are several factors for stripping dry resist for example temperature, spray pressure and the make up of your solution. You should have a data sheet for your resist, where all parameters are described. If you do not have one get one. Good luck Marcus
Marcus Hahn- Sachseln Switzerland
The KOH conc. mainly affects the size of the resist skins formed. Incomplete stripping can be due to a lot of factors; temperature being one of the most important. You don't say if you are stripping in a tank or a conveyor, and you don't mention the possibility of overplating locking in resist chips between traces. These areas are just a few of the possibilities.
James Totter, CEF
- Tallahassee, Florida
