Non-Sticking Coating to Rubber
I need some help about an industrial coating over the rubber hose cores. The cores are made up SS and aluminum. The coating must resist: - 180 °C - wet atmosphere - 6 atm pressure. And it must be non-sticking to rubber at conditions mentioned above. Thanks
Ertan YAZICI- Turkey
You can try with a Teflon coating.Contact to PTFE distributor for the best one (Dupont, Whitford, Acheson, etc).
Jordi PujolCOATRESA SL - Barcelona
I search a non-sticking coating to which very few solid or (I prefer )liquid substances will permanently ( or Semi permanently) adhere to steel mold for the rubber vulcanisation. Thanks for few suggestions
Patrice MEROZ- Joué-les-Tours 37300 France
