Temperature of Hard Chrome Reverse Etch
May 6, 2010
If you are reverse etching in a separate tank than the plating tank, does the reverse etch solution still have to be heated to
120-140F?
Lower temperatures would be more convenient and produce less emissions, but I have never heard of anyone reverse etching at lower temperatures.
Plater - Ogden, Utah
May 6, 2010
Hi, Mark. The etch should be straight chromic acid 26-30 oz/gal, no catalyst, 130 deg F, with the part brought up to bath temperature before power is applied, per Guffie
... but, sorry, he doesn't comment on possible variations except to caution against too dilute solutions.
