Electrolytic reaction - aluminum with stainless and brass
April 28, 2010
I need to fit a plate and tap to several 400 gallon black plastic water tanks which are being used for rainwater harvesting.
Plate that covers exit is 3mm plain aluminium. 4 bolts hold it in place and according to reply on this site if I use 18/8 stainless bolts there will be no reaction with the aluminium.
I cannot get a stainless steel tap. Can anyone tell me whether a brass tap would be OK or would it be better to use a plastic connection through the aluminium plate and fix the tap to the plastic tubing. Worry is that plastic would go brittle after time.
Chris Dore
Engineer and environmental gardener - Southampton, United Kingdom
Hi, Chris. This seems to be for your own personal use, and I'd just put a lot of teflon tape on the brass tap and screw it on in :-)
If this is for a product line, though, I don't think plain uncoated aluminum plate is sufficiently corrosion resistant regardless of what the bolts and tap are made of.
April 28, 2010
