Electroforming gold jewelry on copper, and can't remove last traces of copper
Hi I am goldsmith I work in gold tube bracelets and necklaces,we start the work by coating a copper rod of one c.m. diameter ,with a plate of gold of 0.05 mm. thick,then we continue the process by lowering the diameter of the copper rod which is plated with gold to nearly 0.15-0.2,then we make the bracelet, and after finishing completely we put the bracelet in nitric acid in order to get rid of the copper inside the bracelet,the question is, a thin layer of copper is still sticking to the gold from inside the tube,which is causing to lower the degree of gold,the nitric acid is not cleaning completely, so may someone can show me a way to get rid of that thin layer of copper, will be very grateful
Gar SHAHPRODUCT DESIGNER - BEIRUT, LEBANON
April 26, 2010
April 27, 2010
Hi, Gar. There may be a good reason why you do what you do (my knowledge of jewelry making is limited), but why are you electroforming on copper instead of easier to dissolve materials like wax or aluminum?
u boil the jewellery in nitric acid.use 71% pure nitric acid.
Bhupesh Mulikjewellery - Mumbai, India
May 5, 2010
H2SO4 3 parts and nitric acid 1 part
Majed Janineh- Beith Lehem Palistain
September 27, 2011
