Using a former fuel oil tank as a DM water tank
April 25, 2010
Dear sir,
I have to use a Fuel oil tank as DM tank. I need to know how can we make it work?
we have cleaned it First with turpentine
⇦ this on
Amazon [affil links]
, then with caustic soda ⇦liquid caustic soda in bulk on
, with normal water. When we see it it feels that it can be used as DM tank,But still I want to know what parameters we should check for, so that it can be used as DM storage tank.
2. If it needs to be cleaned then which procedure should we follow?
(Note:The tank was used to store petroleum products)
employee - Hapur, Uttar Preadesh, India
April 28, 2010
Oil tanks are usually made of mild steel and are not suitable for demineralized water because the water will aggressively dissolve the iron.
DM water is usually stored in non-metallic or in stainless steel vessels.
