Spots appear on zinc plating after 48 hours under normal environment
Base metal is 4130, with zinc plating. Being put in stock in plastic bags for 2 or 3 days, corrosion spot appears on the surface. Other parts were plated at the same line does not have this problem. Even several replatings can't solve this problem. Cyanide plating bath, 8-10 µm thickness, Pavco trivalent chromate. The parts were replated at another plater, alkaline plating bath, 10um, Yuken trivalent chromate, but with same issue. What is the root cause?
Sharon LuoSupplier chain - Shenzhen, GuangDong, China
April 21, 2010
Pitted parts, cold shuts and bad alloy comes to mind.
James Watts- Navarre, Florida
April 23, 2010
Second of two simultaneous responses -- April 26, 2010
Hi,
Is it a cast iron, may be its too porous, I would suggest to have an acid zinc plating, then heat it and then passivation followed by a silicate sealant.
Hope this would help to achieve better corrosion protection.
Best Regards
Praveen Kumar
plating process supplier
Mumbai, India
Sounds like you are plating castings to me. Correct?
Trent Kaufman
electroplater - Galva, Illinois
April 26, 2010
Sharon
What happens if you do NOT bag the part? Are the parts dry when you bag them? Have you tried a different supplier of bags, or material? Do you bag other parts without issue?
- Colorado Springs, Colorado
April 28, 2010
