Electroless copper plating on PVC pipe
Am design new antenna which uses PVC pipe as a substrate which must be completely Cu plated on the interior and a spiral geometry on the exterior of the pipe. Cannot seem to source any company that does PVC plastic Cu plating. Can anyone direct me in this manner to possible plater? I understand that initial Cu deposition must be electroless method.
RF Antenna Designer Tampa, Florida
April 10, 2010
PVC is very difficult if not impossible to etch chemically. It is highly corrosion resistant to most chemicals and hydrophobic, so, most platers will be reluctant to to guarantee results or even try. Have you considered ABS instead?
April 14, 2010
