In-house test for passivation of stainless steel
Q. What is the in-house test to check the SS 304 against rusting?
Hardik Ozaice cream co - Bhopal, India
March 20, 2010
A. Do you mean a process for checking to see if the parts have been properly passivated? If so, a common test is called the copper sulphate ⇦ this on eBay or Amazon [affil links] test. Make a one liter solution containing 16 g of copper sulphate pentahydrate and 5 mL of reagent grade sulfuric acid. Keep the surface wet with the stuff for 6+ minutes by saturating some lab filter paper that is placed onto the stainless steel. After the time is up, rinse and then dry. If you see any copper-colored deposit on the stainless, then the part surface is insufficiently passive (contains free iron).
Side note- Some people say that you should make fresh copper sulphate solution every two weeks, but if it is stored properly it has an indefinite shelf-life.
Jon Barrows, MSF, EHSSC
Independence, Missouri
March 22, 2010
Q. Can someone please answer why there is a 2 week pot life for copper sulphate in MIL-STD-753
[⇦ this spec on DLA / cancelled]?
Thanks in advance.
Mike
engineering - Ottawa, Ontario. Canada
May 27, 2014
May 28, 2014
A. Mike,
One reason for a time limit is because the Cu tends to plate out of the solution in question and onto the container in storage over time. When one uses a fresh blue batch compared to a used gray batch it makes a big difference. For example, you can still get some use out of a partly "spent" batch of solution but the reaction times can be very slow and easily impact testing guidelines rendering any tests pointless (parts can pass the test that should not pass).
Blake Kneedler
The same question was asked among the relevant groups in ASTM and SAE, nobody could think of any reason, and the two-week time limit was removed from the active passivation standards.
The notion of the copper plating out in the container is the first attempt I've ever seen to explain this, though I think this is only a possibility if using a carbon steel container. I don't see that ever happening in glass or plastic. The copper sulphate solution should in general be stable and inert over time unless exposed to a reactive metal.
This of course assumes that you are drawing from the container to test drop-wise on the surface of parts. I know for very small parts folks tend to just dunk the whole thing in the solution. If you get a lot of failures when doing this, yes it will start to deplete the copper in the bath.
Ray Kremer
Stellar Solutions, Inc.
McHenry, Illinois
May 29, 2014
Thank you for all your responses. Since we are spraying on the copper sulphate to 304 and 321 stainless and not dipping any parts into the solution directly, I will disregard the pot life suggestion of 2 weeks.
Davis Engineering - Ottawa, Ontario. Canada
May 30, 2014
A. Copper sulphate/sulfuric acid test solution is stable indefinitely. Analytical standard solutions of high accuracy have no expiry date.
There are many incomprehensible specs un use, particularly in-house ones where the originator had only a tenuous grasp of the principles involved. If you don't like the spec challenge it.
However, the reason behind this particular time limit is probably illustrated by the reference to a 'grey used batch'.
This is evidence of the very bad (but not uncommon) practice of returning used solution to the stock bottle.
The two week limit was probably set as the maximum time the test could stand this misuse and still give a reasonably reliable result.
If the used solution is discarded after every test, the stock solution should not deteriorate.
BUT there is one thing certain about all specs. If they are part of the purchase agreement, you have a contractual obligation follow them exactly.
Q. The ASTM A380
(94) in past revisions used to say the solutions could not be more than 2 weeks old.
However, the Newest revisions (2017) removed the 2 week limitation.
Since some of our qualified programs had the old requirement written into them, the customers will not agree to just drop the expiration date requirement without some kind of "proof"
Is there some paper (or documentation of the section discussion when they dropped it) that will prove there is no expiration date so I can change our procedure and give this proof as evidence?
We would like to just get some solution and use it until it is gone. We are making our own now because we have to (the 2 week expiration). I'd rather get out of the business of mixing standards.
Flexial Corp - Cookeville, Tennessee USA
July 22, 2019
October 15, 2019
A. Mickie,
Darn, I didn't see this until now. Sorry for the late answer.
No study was done, there is no paper or documentation really, just some chemists that know darn well a solution of copper ions and sulphate ions isn't going to go anywhere, certainly not in as short a time as two weeks. Nobody in ASTM A01 committee disagreed, so out went the two week limit.
However, the aerospace people agreed with your customers, and even though they allowed the two week shelf life to be dropped from AMS2700, they replaced it with a requirement to constantly make sure the solution is "still good" by testing it on a piece of carbon steel. If you promise to do the same when testing your customer's parts, maybe they will allow it.
Ray Kremer
McHenry, Illinois
