Galvanic Corrosion - Stainless Steel Rod with Carbon Steel Nut
Q. Will a carbon steel nut on a stainless steel rod act as an anode to help prevent the rod from corroding if they are submerged in seawater?
I read another similar post here that used an example of steel wool on a stainless steel sink causing it to rust. However, it seems that the carbon steel nut would act as a sacrificial anode and protect the rod. Is that not correct?
Craig
Craig Stewart
student - Winston-Salem, North Carolina
March 2, 2010
A. Interesting question, Craig. It's nice to see students thinking. Yes, a plain steel nut should serve as a sacrificial anode on a stainless steel rod, but probably not a very practical one because it's life would be short.
I think steel wool causes rusting of stainless steel by imbedding small particles of steel into it.
