Carbon in gold plate
February 25, 2010
Hi
George here,
I'm interested in introducing carbon into a gold plating process, is this possible?
Thank You
hobbyist - Attleboro, Massachusetts, USA
Hi, George. Anything is possible. The devil is in the details. What are you trying to accomplish?
February 26, 2010
February 28, 2010
George
All gold deposited from the usual GPC bath contains some carbon in the form of a co-deposited cyanide polymer. This adds some lubricity to the deposit and is part of the reason why electroplated gold has a density of about 17.5 g/c rather than the 'book' density of 19.3 g/cc. Which also explains why thickness/wt calculations are often misleading and lead to endless arguments with inspectors and buyers.
But - if you want lumps of elemental carbon in the deposit, you probably only have to create a suspension of carbon in the plating solution. Don't expect to get a smoooth deposit tho. Getting the particle size etc right may not be easy and gold solutions are expensive to play with.
But, as Ted says, if you tell us what you are trying to achieve, you might get more helpful answers
Good luck
