Is a Finish Required
My company typically uses hot dipped galvanized steel for exterior structural work. We are considering using some aluminum for some exterior structural applications but I am not sure if it is acceptable to use a plain mill finish. Appeaarnce is not an issue, it is just a question of how long will a plain mill finish aluminum last? I understand that there are many factors that affect corrosin rates, but was hoping someone had some general information on expected life cycle.
Michael Zuritis
Contractor - Ballston Lake, New York, USA
February 10, 2010
I used to do some pretreatment work for aluminum that fell under architectural standards. You might want to search for those and start there.
Christian M. Restifo
- Pittsburgh, Pennsylvania
March 3, 2010
You will need some type of pretreatment and finishing of the Al. The Zinc and Al will set up a galvanic cell and the bimetallic corrosion will attack the galvanizing.
David J. Wolf
David J. Wolf
Medina, Ohio
March 10, 2010
