Ratio for caustic soda solution
What should be the ratio for caustic soda ⇦liquid caustic soda in bulk on Amazon [affil link] solution used for degreasing in hot dip galvanizing
Suresh T.- Noida,U.P, India
February 10, 2010
Suresh,
Ratio of caustic to what?
February 12, 2010
February 12, 2010
Sir:
Most hot dip galvanizers that use H2SO4 (sulfuric acid)pickle use caustic soda ⇦liquid caustic soda in bulk on
(sodium hydroxide) at 10% solution. Most hot dip galvanizers that use HCl (hydrochloric acid) pickle use caustic soda at about 5% to 8%. The usual temperature for caustic soda solution is from about 60C to 70C.
