Acid Recovery System for pickling wastewater
February 6, 2010
DEAR SIR, GREETINGS,
WE ARE AN ASSOCIATION OF INDUSTRIES. WE HAVE INSTALLED A COMMON EFFLUENT TREATMENT PLANT (PHYSIO-CHEMICAL TREATMENT PROCESS- S/G+PC+DMF+GAC+CI 2). MAJORITY OF WASTE WATER DISCHARGE IS FROM STAINLESS STEEL COLD ROLLING INDUSTRY, WHICH ARE DURING THE MANUFACTURING PROCESS OF THE S S SHEETS HAVE TO ACID PICKLE THE SHEETS WITH A PICKLE BATH OF HYDROFLUORIC ACID (HF), NITRIC ACID (HNO3), sulfurIC ACID H2SO4. THE INLET QUALITY OF WASTE WATER GENERATED BY THESE UNITS IS:
SL. NO.
PARAMETERS
VALUES IN MG/L (EXCEPT PH)
1
PH
1-1.8
2
TEMPERATURE OC
29
3
OIL & GREASE
4
PHENOLIC COMPOUNDS (AS C6H5OH) MG/L
28.72
5
AMMONICAL NITROGEN (AS N)
6
CYANIDE (AS CN)
ND
7
HEXAVALENT CHROMIUM (AS CR+6)
8
TOTAL CHROMIUM (AS CR)
9.3
9
COPPER (AS CU)
10
LEAD (AS PB)
12.95
11
NICKEL (AS NI)
12.06
12
ZINC (AS ZN)
1.11
13
ARSENIC (AS AS)
0.20
14
MERCURY (AS HG)
0.04
15
CADMIUM (AS CD)
0.12
16
SELENIUM (AS SE)
17
FLUORIDE (AS F)
18
BORON (AS B)
RADIOACTIVE MATERIALS
19
ALPHA EMITTERS, HC/ML
20
BETA EMITTERS, HC/ML
21
SUSPENDED SOLIDS
79
22
DISSOLVED SOLIDS (INORGANIC)
3892
23
TOTAL RESIDUAL CHLORINE
24
TOTAL KJELDAHI NITROGEN (AS N)
45.20
25
COD, MG/L
26
PERCENT SODIUM
27
CHLORIDE (AS CL) MG/L
860
28
SULPHATE (AS SO4), MG/L
2080
29
sulfide (AS S), MG/L
ND
30
PESTICIDES
31
BOD5 20OC
27 (BOD3 27OC)
32
CONDUCTIVITY, MS/CM
5.23
33
NITRATES, MG/L
8.50
34
NITRITES, MG/L
0.08
35
PHOSPHATES, MG/L
4
36
TOC, MG/L
52
37
IRON
368.7
38
Manganese
49.3
39
ALKALINITY (AS CACO3), MG/L
ALTHOUGH THE RESULTS OF TREATED EFFLUENT ARE WELL WITHIN THE PRESCRIBED LIMITS BUT MAIN PROBLEM IS OF GENERATION OF HIGH QUANTITY OF SLUDGE AND THE ACIDIC WATER IS DAMAGING THE INFRASTRUCTURE/ EQUIPMENTS.
SL. NO
PARAMETER
EPA STANDARDS
1
PH
5.5-9.0
7.1
2
TSS
100
46
3
COD
250
96
4
BOD
30
27
5
NI
3
0.84
6
CU
3
0.92
7
ZN
5
0.84
8
CR
2
1.38
9
CR +6
ND
10
PB
0.1
0.06
11
TRC
1
ND
12
CI
1000
900
13
SO4
1000
155.8
14
CD
1
0.84
15
O&G
10
2
16
TDS
2100
4960
17
PHENOLIC COMPOUNDS
1
18
AMMONICAL NITROGEN AS N
50
2.7
19
CYANIDE AS CN
0.2
20
FLUORIDE
2
2.4
21
sulfide
2.8
1.8
WE ARE LOOKING FOR A SOLUTION TO OUR WASTER WATER FOR RECOVERY OF ACID TO AVOID EXCESS LOAD ON OUR CETP AS WELL AS TO SAFEGUARD OUR SYSTEM. ARE SUCH SYSTEM AVAILABLE OR THEY ARE JUST RUMORS IN THE MARKET ABOUT THEIR AVAILABILITY.
THANKS IN ADVANCE AND BEST REGARDS,
LEGEND:
S SCREEN CHAMBER
G GRIT CHAMBER
CI 1 PRE CHLORINATION
CI 2 POST CHLORINATION
PC PHYSICO CHEMICAL
PSF PRESSURE SAND FILTER
DMF DUAL MEDIA FILTER (SAND & FLY ASH)
GAC GAC - GRANULAR ACTIVATED CARBON COLUMN
EA EA - EXTENDED AERATION TANK
SST SST - SECONDARY SETTLING TANK
S K Tandon
general secretary of confederation and actual user. - Delhi, India
