Air Agitation for an anodizing tank
January 28, 2010
What is the best method of agitation for a small anodise bath
(1379 mm wide 650 mm deep 740 mm high)?
At present we are using a drilled rectangular 25 mm galvanised steel ring but we're experiencing problems with agitation near the bottom of the bath.
anodising shop - Redruth, Cornwall, UK
January 28, 2010
If you can, find a copy of the Metal Finishing Guidebook. It has a section that explains agitation perfectly.
www.finishing.com/books/MFG.shtml
If you want more specific help, you need to tell us what type of anodizing you are performing and more details about your current agitation system. Using galvanized steel pipe in an anodizing bath is a bit puzzling.
Jon Barrows, MSF, EHSSC
Independence, Missouri
