Soak temp and time
January 24, 2010
What is the recommended speed of run up.
What temp to achieve.
Duration of soak
The material is CS 38" Dia x 32mm wt, the line is carrying soar gas
Randy Holt
Inspector - Doha Qatar
Hi, Randy. We are not there with you and don't know what you are talking about. Are you saying that you have a 38" diameter piece of cast steel pipe that you wish to clean because it has been exposed to "sour gas" from an oil drilling field, or "sewer gas" in a water treatment plant? Or that you wish to clean in preparation for that kind of service? Please spend a few paragraphs explaining your situation. Thanks!
January 26, 2010
