Thread 541/03
Controlling Zinc Granules on edges of galvanized coils
January 14, 2010
Dear all
For a period of time I am making a research to control the appearance Zinc Granules on the coil edge in the process of galvanization.
I need to know what is the efficient way to control this matter.
thank you
galvanizing plant - Q.A - Amman, Jordan
publicly reply to Ayman Hassouneh
January 15, 2010
Sir:
I have several means to solve the problem you describe.
If you post a few photos it would be informative.
publicly reply to Dr. Thomas H. Cook
Dear Mr. Cook;
Thank you for your response.
I'll upload some photos for the case I asked about.
Best Regards.
- Amman, Jordan
January 19, 2010
January 19, 2010
Sir:
I am having some difficulty orienting to the photos. What there seems to be are granules; and grooves and ridges. What type kettle do you have? Ceramic or iron? How long has it been in operation? Do you use a flux solution or (more likely) nitrogen/hydrogen? Could you describe the problem further? What is your usual aluminum? Could you section the granules and etch them and do SEM/EDX of the composition of these granules?
January 21, 2010
Dear Sir;
well, we are using a ceramic/glass kettle, operated in 2008. we use the nitrogen/hydrogen in our line.
The AL is 10% - 15%.
regarding the tests required I'll post the results within 2 days once they are ready.
hereby another photo, which it may clarify the case.
Best Regards.
Ayman Hassouneh, Q.A- Amman, Jordan
publicly reply to Ayman Hassouneh, Q.A
January 22, 2010
Sir:
If it is true that you use 10% to 15% aluminum in your molten zinc bath, then I am not qualified to help you further. If however you are using 10% or 15% Aluminum; Balance Zinc as the means to maintain around 0.2% aluminum in your molten zinc then I may be able to help you.
Even Galfan has only 5% aluminum in the zinc (This is a low melting eutectic). I still wonder if your aluminum additions are uniform.
