Hard chrome plating solution effect on cadmium plated part
December 31, 2009
My question is: can a steel part be flash hard chrome plated in one area and the adjacent area be cadmium plated. Should the part be be hard chromed or cadmium plated first or does it matter.
Steve Heller
Plating shop - Cincinnati, Ohio, USA
simultaneous replies January 5, 2010
The part will need to be masked either way, in all probability. Chrome plating solution will attack the cad far faster than the cyanide cad will attack the chrome, so I would try the chrome first. Either way, you need to go in HOT.
If your chrome tank is much above ambient temp, I would warm the part up in a hot rinse tank before going into the chrome IF you decide to try the cad first.
I do not like the term "flash hard chrome" as hard chrome needs some thickness much higher than a flash to serve a normal hard chrome function. I will buy using a hard chrome tank to put a chrome flash on a part. Probably semantics, but once it gets into print, it can be misinterpreted by someone.
In my experience you would chrome plate first and then cadmium plate, probably with a very small overlap onto the chrome so that there is no exposed base metal.
Brian Terry
January 6, 2010
Steve,
