Galvanize Line: Changing from sulfuric Acid Pickle to Hydrochloric
I work with a hot dip galvanize operation and am looking into the possibility of changing from sulfuric acid in the pickle line to hydrochloric acid. I need to know what strength of hydrochloric is recommended and can it be used for stripping galvanize. Thanks for any help.
Brian M. Ruiz
- Oklahoma
Used to visit a UK galavaniser of steel windows. They used ferric chloride this on eBay or Amazon [affil links] at 10-20% + 10%HCl (cold). You could use 30-40% solution of commercial HCl dosed with inhibitor (Stannine LTP is good). This will also strip zinc. R
Roger Bridger
- Croydon, UK
changing to Hydrochloric acid pickling can be done in two ways:
1. Low iron chloride/high hydrochloric acid content 2. High iron chloride/low hydrochloric acid content
There are graphs available for the ratio iron/acid.
High iron chloride/ low acid has the advantage of low acid consumption and low waste acid amounts. Pickling is more smooth because iron chloride is hardly attacking the basic iron. Waste acid without zinc in it can often be reused for instance for water treatment (Iron chloride).
Stripping in hydrochloric acid will produce zinc chloride. With a flux regeneration(de-ironing)you can reuse a part of the stripping acid(zinc chloride) as a fluxing salt.
Dolf van den Berg
Dolf van den Berg
- Leusden, The Netherlands
We are at the research stage to construct a flux regeneration plant for our facility.
I want to learn how much H2O2 addition should we make for each ton of material we immerse into the bath. Thanks for the help.
Deger Saygin
- Izmir, Turkey
