I want to darken a piece of steel sheet as a fire back in a gas fired domestic setting
December 22, 2009
I am a householder seeking a neat and affordable solution, my apologies if this is outside the site's scope.
Brick/ceramic fire backs tend to crack and discolor with over time, much to the disappoinment of the proud housewife.
A thin, treated and resistant steel surface could be prefabricated or be malleable enough to fit into a new or existing fireplace.
A pilot study should readily decide the fabricability and lifetime expectancy of such sheet metal....
HOUSEHOLDER - STOCKPORT UK
Indeed, Alan, neat and affordable solutions are outside of the site's scope. We only suggest sloppy and expensive approaches :-)
But really, a black oxided surface on the steel should be a good start to it starting and staying generally black. Good luck.
December 22, 2009
