Need etching formula for ceramic bathtub which will not rust metal
December 17, 2009
I have been etching porcelain bathtubs to make the more slip resistant but HCl keeps discoloring the drain. What can I change to keep it effective without discoloring metal?
0.5% ABF
2.5% HCL
Rest water
Should I add Oxalic Acid or replace HCl with Sulufric acid? Any other suggestions?
Joe Mann
student - Texas
Hi, Joe. If you have developed a good way to etch porcelain bathtubs, I wouldn't change it. Rather I would figure out a reliable way to mask the drain with a plug, cap, platers' tape, or liquid maskant. I hope you mix the HCl at a remote location. You should not bring strong HCl into your customers' bathrooms as it fumes and the fumes alone will destroy other brightwork.
December 17, 2009
finishing.com is possible thanks to our supporting advertisers, including:
maskcoat banner
