Contact material for Corrosion Resistance to Salt Water and Chlorine Water
My company is developing an electronic product for swimming. The charging contacts will be exposed to ocean salt water as well as salt and chlorine pool water.
What would be the best material / finish to resist corrosion?
Product Designer - Holland, MI, USA
December 18, 2009
Hi, Todd. I would think electroless nickel is appropriate.
December 18, 2009
You need enclosure? What part should be protected from corrosion?
Shanmugavel Thangappan- Madurai, Tamil Nadu, India
January 6, 2010
