Need a clear coating to preserve color anodizing on titanium
December 16, 2009
Greetings, I have a custom made titanium flashlight that was recently textured and flame anodized to a beautiful rainbow pattern. I would like to find a gloss clear coat that will protect the color anodizing from wear.
Obviously, no mechanical metal preparation can be done, as the anodizing is thin.
I was thinking of clear powder coating but not sure if the anodizing is conductive enough for that process. Any thoughts on a clear epoxy or acrylic spray?
Thanks for your help.
Mark Miller
hobbyist - Philadelphia, Pennsylvania
December 17, 2009
Hi, Mark. It doesn't sound promising. letter 28243 implies that clear coats won't stick, although letter 35475 implies that one brand will. Letter 40569 implies (and I tend to believe this although I haven't tried it) that the coloration will be removed by the clear coating because it's only a diffraction pattern (like an oildrop rainbow on water), so as soon as you add a 2nd clearcoat on top of the thin clear titanium oxide which is causing the diffraction, the cause of the coloration is gone.
