What is the difference between carbon steel and titanium pipe
hi ...
I am Jeyaprakash.. I want to know about titanium pipe...please can you briefly introduce....
Jeyaprakash seeni
December 14, 2009
Hi, Jeyaprakah. Titanium is an element. You can easily research it's general properties. In general, it is light, strong, and corrosion resistant. If you can put your question in context, someone may be able to help you.
December 15, 2009
The difference between these pipes are based on the applications in which they are used.
Generally carbon steel is the default pipe material for non-aqueous fluid processes, due to high strength and low cost.
To make the right choice, you will need to know the chemicals and pressures these pipes will be exposed to.
Robert H. Kinner
- Toledo, Ohio
