Is hydrogen de-embrittlement required after chrome plating?
Is hydrogen de-embrittlement (degassing) required after chrome plating? If so what should be the temperature?
Narasimman VS
employee - Chennai, India
December 5, 2009
Hi, VS. High strength steel requires hydrogen de-embrittlement after a pickling or electroplating process. Mild steel does not. It must be done almost immediately at a temperature of about 375 deg. F., but there may be a spec for the parts in question. Please search the site for dozens of threads about hydrogen embrittlement. Good luck.
December 6, 2009
Hi Narasimman,
Degassing treatment process depends on the base material strength and hardness before plating.
refer to the below standards:
ISO 9587: Metallic and other inorganic coatings ¨ Pretreatment of iron or steel to reduce the risk of hydrogen embrittlement.
ISO 9588: Metallic and other inorganic coatings ¨ Post-coating treatments of iron or steel to reduce the risk of hydrogen embrittlement
You will get more information.
- Salem,Tamil Nadu, India
January 8, 2010
Does pickling of steel in HCl acid cause any hydrogen embrittlement the weld in a tube or pipe?
Tom Lampingsales - Davenport, Iowa
January 15, 2010
Hi, Tom. Yes, HCl pickling is a hydrogen generating process and can cause hydrogen embrittlement in hardened steel.
January 18, 2010
