Electroless nickel plating of carbon/epoxy composites
I am considering the plating a hardsurface (nickel) on a compression molded carbon/epoxy prepreg surface. This would be to achieve a wear resistant surface without having to attach a multislide type "clip". Can this be done using electroless nickel or a similar electrodeposition process?
James Dreherproduct designer - Durham, New Hampshire
November 19, 2009
Hello! We plate this material all the time. Feel free to call to discuss requirements. Regards Rob Coffie
Rob CoffieWarren, Michigan, USA
January 4, 2010
