Blackening annealed steel wire
November 18, 2009
Hello,
My name is Larry Ianni. I am looking for a room temperature dip that I can place a 5 pound annealed steel wire coil into to turn the steel wire black. I use this metal wire for the balance arms to mobiles.
Larry
Larry Ianni
hobbyist - Trenton, Michigan
Stovepipe Wire
Well if it was me. I'd run down to the hardware store and buy a roll of stove pipe wire. It it costs less than $10. Comes in varying thickness's and is in rolls of 20 yards or so and the best thing .... its black and soft as butter. Just a thought!
rod henrickson
Rod Henrickson
gunsmith - Edmonton, Alberta, Canada
November 20, 2009
Try 20 gm tannic acid this on eBay or Amazon [affil links] /15 gm phosphoric acid/ 1 lit water.Wire must be scale and grease free.Immerse in solution(10 seconds is OK).When dry immerse in beeswax this on eBay or Amazon [affil links] dissolved in turpentine this on eBay or Amazon [affil links] or white spirit(50 gm wax/1 lit white spirit).Instead wax solution you can use 35-100 gm Paraloid B 44 acryl resin dissolved in toluene or acetone this on eBay or Amazon [affil links] Warning! highly Flammable! .Hope it helps and good luck!
- Zagreb,Croatia
November 21, 2009
Thank you Rod Henrickson and Goran Budija for your input.
Larry Ianni
- Trenton, Michigan, USA
December 3, 2009
