Tolerance band for finish: Rz=10um AND Rzmax=20um
November 18, 2009
There are two requirements under the surface finish symbol
Rz=10um
Rzmax=20um
Are these upper and lower limits of the finish allowed?
Quality manager - Mason, Ohio
If these 2 numbers appear side by side or next to each other, I would say you are correct to assume they are a min max notation; however check title block to see if there is a tolerance indicated there. If tolerance is there, then it is not min, Max. Last and simplest way is to ask the originator of dwg. or company requesting info.
AF Kenton
December 11, 2009
